Configure system message control to suppress duplicate error messages on the console, and to determine the action to take if they occur.
Switch:1(config)#sys msg-control action suppress-msg Switch:1(config)#sys msg-control max-msg-num 10 Switch:1(config)#sys msg-control control-interval 15 Switch:1(config)#sys msg-control
The following table defines parameters for the sys msg-control command.
Variable |
Value |
action <both|send-trap|suppress-msg> |
Configures the message control action. You can either suppress the message or send a trap notification, or both. The default is suppress. |
control-interval <1-30> |
Configures the message control interval in minutes. The valid options are 1–30. The default is 5. |
max-msg-num <2-500> |
Configures the number of occurrences of a message after which the control action occurs. To configure the maximum number of occurrences, enter a value from 2–500. The default is 5. |
