Configure a VLAN on a Port
Configure a VLAN on a port.
VLAN Field Descriptions
Use the data in the following table to use the VLAN tab.
Name |
Description |
PerformTagging |
If checked, this port is a tagged (Trunk) Port. It can belong to multiple port-based VLANs and a VLAN tag is inserted in every frame it transmits. If it is not checked, the port is an untagged (Access) port. The default is disabled. |
VlanIdList |
Identifies which VLANs this port is assigned. |
DiscardTaggedFrames |
If selected, and the port is untagged (an access port), tagged frames received on the port are discarded by the forwarding process. If clear, tagged frames are processed normally. The default is disabled. |
DiscardUntaggedFrames |
If selected and the port is tagged (a trunk port), untagged frames received on the port are discarded by the forwarding process. If clear, untagged frames are processed normally. The default is disabled. |
UntagDefaultVLAN |
If selected, even if the port is tagged (a trunk port), frames forwarded to the default VLAN for the port are not tagged. The default is disabled. |
UntaggedVlanIds |
Identifies which VLANs this port is associated with as untagged. |
DefaultVlanId |
Specifies the VLAN ID assigned to untagged frames received on this trunk port that match no policy-based VLAN to which the port belongs. |
SpoofDetect |
Enables or disables spoof detection on the specified port. |
PrivateVlanPortType |
Specifies the port type for a Private VLAN. If not specified, the port type defaults to None.
Origin |
Specifies the origin of VLAN configuration on the port, either manually configured through CLI or EDM, or dynamically configured through Auto-sense. |
