You must configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
You must create the customer VLANs (C-VLANs) and add slots/ports.
Important
When a protocol VLAN is created, all ports are added to the VLAN including SPBM ports. To configure a protocol-based VLAN as a C-VLAN, you must first remove the SPBM-enabled ports from the protocol based VLAN, and then configure the protocol-based VLAN as a C-VLAN.
The switch reserves I-SID 0x00ffffff. The switch uses this I-SID to advertise the virtual BMAC in an SMLT dual-homing environment. The platform clears the receive and transmit bit of this I-SID, therefore I-SID 0x00ffffff cannot be used for any other service.
