Unable to Log On Using SSH
If you cannot log on using Secure Shell (SSH), perform the following steps.
Verify whether you enabled and configured SSH function correctly on the switch:
Switch:1(config)#show ssh global
Total Active Sessions : 1
version : v2only
port : 22
max-sessions : 4
timeout : 60
action rsa-host key : rsa-hostkeysize 2048
action dsa-host key : dsa-hostkeysize 1024
rsa-auth : true
dsa-auth : true
pass-auth : true
keyboard-interactive-auth : false
x509-auth : true
x509-auth Trustpoint CA Name :
x509-auth Identity Subject Name : not configured
x509-auth overwrite : false
x509-auth strip-domain : false
x509-auth use-domain : -
x509-auth revocation-check-method : OCSP
sftp enable : true
client enable : true
enable : true
authentication-type : aead-aes-128-gcm-ssh aead-aes-256-gcm-ssh hmac-sha1 hmac-sha2-256
encryption-type : 3des-cbc aead-aes-128-gcm-ssh aead-aes-256-gcm-ssh aes128-cbc aes128-ctr
aes192-cbc aes192-ctr aes256-cbc aes256-ctr blowfish-cbc rijndael128-cbc
rijndael192-cbc
key-exchange-method : diffie-hellman-group-exchange-sha256 diffie-hellman-group14-sha1
diffie-hellman-group14-sha256 diffie-hellman-group16-sha512
diffie-hellman-group18-sha512
