Display Fabric KHI Resource ScalingNEW!
Perform the following procedure to display Key Health Indicator (KHI) information to determine the resources available for Fabric scaling.
  1. To enter User EXEC mode, log on to the switch.
  2. Display Fabric KHI scaling resource information:
    show khi resource-scaling
Switch:1>show khi resource-scaling
         KHI resource-scaling
Resource                                   Current       Maximum       Available    Usage
                                                       (theoretical)
SPBM nodes
SPBM nodes - home area                     160           500          340           32 %
SPBM nodes - remote area                   130           500          210           27 %
Total SPBM nodes                           293           1000         550           34 %
BMACs
Nodal sys-id B<ACS (*N1)                   293           1000         550           34 %
VIST virtual BMACs                         141           N/A           -            -
Multi-area boundary node redirect BMACs    44            N/A           -            -
MCoSPB source BMACs (*N1, *N2)             293           1000         707           70 %
Total BMACs                                771           1000         229           77 %
ISIS
Physical ISIS interfaces                   2             N/A           -            -
L2FE ISIS interfaces                       0             N/A           -            -
L3FE ISIS interfaces                       0             255           253          0 %
Total ISIS interfaces                      2             255           253          1 %
Services
Multicast-fib entries                      11            35000         34989        1 %
L2VSNs                                     7             N/A           -            -
L2VSNs redistributed                       0             9600          9600         0 %
Transparent UNIs                           0             56            0            0 %
Switched UNIs                              3             12000         0            1 %
Private VLANs                              0             200           200          0 %
L3VSNs                                     1             256           255          1 %
Services - IP multicast
Multicast local streams                    0             4000          4000         0 %
Multicast remote streams                   0             6000          6000         0 %
Total multicast streams                    0             6000          6000         0 %
Multicast streams redistributed inter-area 0             4800          4800         0 %
DVR
DVR enabled L2VSNs                         1             250           249          1 %
DVR domains count                          0             16            0            0 %
DVR controllers in current domain          3             8             5           37 %
DVR leaves in current domain               0             250           250          0 %
DVR host routes
DVR host routes home area                  3             40000         -            -
DVR host routes remote area                0             40000         -            -
DVR host routes redistributed              0             13900         13900        0 %
DVR host routes overall                    3             40000         39997        1 %
** Details:
 *N1 - physical nodes and MA virtual nodes
 *N2 – BEBs sending traffic to this node
