Configure IP Shortcuts and layer 3 VSN on the Virtual Router Forwarding (VRF) instance.
Perform this procedure to configure IS-IS Multi-area SPB IPv6 unicast redistribution on a specific Virtual Router Forwarding (VRF) instance on the switch.
Configuring IS-IS Multi-area SPB IPv6 unicast redistribution for home to remote direction:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf VRF1
Switch:1(router-vrf)#isis multi-area ipv6 redistribute unicast home-to-remote
Switch:1(router-vrf)#isis multi-area ipv6 redistribute unicast home-to-remote route-map test
Switch:1(router-vrf)#isis multi-area ipv6 redistribute unicast home-to-remote enable
Switch:1(router-vrf)#show isis multi-area ipv6 redistribute unicast home-to-remote vrf VRF1
ISIS Multiarea Redistribute List for ipv6 unicast - VRF VRF1
DIRECTION ENABLE RPOLICY
home-to-remote TRUE test
Switch:1(router-vrf)#exit
Switch:1(config)#isis multi-area ipv6 apply redistribute unicast home-to-remote vrf VRF1
The following table defines parameters for the isis multi-area ipv6 redistribute unicast and the isis multi-area ipv6 apply redistribute unicast commands.
| Variable | Value |
| enable |
Enables IPv6 unicast redistribution on the VRF instance. |
| home-to-remote |
Specifies the IPv6 unicast redistribution configuration for home to remote direction. |
| remote-to-home |
Specifies the IPv6 unicast redistribution configuration for remote to home direction. |
| route-map WORD<1-64> |
Specifies the name of the route policy. |
| vrf WORD<1-16> |
Specifies the IPv6 unicast redistribution configuration for a specific VRF instance. |
