Disable IP Source Guard (IPSG) on a port to allow traffic from all IPv4 addresses to go through the port without being filtered.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Disable IPSG for IPv4 addresses:
    no ip source verify
  3. Verify IPSG configuration:
    show ip source verify interface gigabitethernet [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Disable IPSG on port 1/1.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#interface gigabitEthernet 1/1
Switch:1(config-if)#no ip source verify
Verify the configuration.
Switch:1(config-if)#show ip source verify interface gigabitEthernet 1/1
                             Source Guard Port Info
PORT                     IPSC
NUM        ENABLE        ORGIN
1/1        false         RADIUS
All 1 out of 1 Total Num of Ip Source Guard entries displayed
