Use the following procedure to configure SCI tagging on a MACsec-enabled switch. The default is disabled.
If you are running VOSS 8.4.2 or earlier, disable SCI tagging on the switch.
enable
configure terminal
macsec mka profile WORD<1-16>
include-sci enable
The configuration should be the same at both ends of the link, either enabled or disabled.
