- Select Policy.
- Select the Route Policy tab.
- Select Insert.
- Enter the appropriate information for your configuration in the Insert Route Policy dialog box.
- Select Insert.
Route Policy Field Descriptions
Use the data in the following table to use the Route Policy tab.
Name |
Description |
Id |
Specifies the ID of an entry in the Prefix list table. |
SequenceNumber |
Specifies a policy within a route policy group. |
Name |
Specifies the name of the policy. This command changes the name field for all sequence numbers under the given policy. |
Enable |
Indicates whether this policy sequence number is enabled or disabled. If disabled, the policy sequence number is ignored. The default is disabled. |
Mode |
Specifies the action to take when a policy is selected for a specific route. Select permit (allow the route) or deny (ignore the route). The default is permit. |
MatchProtocol |
Selects the appropriate protocol. If configured, matches the protocol through which the route is learned. This parameter applies only for RIP Announce purposes. The default is to enable all match protocols. |
MatchNetwork |
Specifies if the system matches the destination network against the contents of the specified prefix list. |
MatchIpRouteSource |
Specifies if the system matches the next-hop IP address for RIP routes and advertising router IDs for OSPF routes against the contents of the specified prefix list. This option is ignored for all other route types. Select the ellipsis and choose from the list in the Match Route Source dialog box. You can select up to four entries. To clear an entry, use the ALT key. You can also change this field in the Route Policy tab of the Policy dialog box. |
MatchIpRouteDest |
Specifies if the system matches the next-hop IP address for RIP routes and advertising router IDs for OSPF routes against the contents of the specified prefix list. This option is ignored for all other route types. |
MatchNextHop |
Specifies if the system matches the next-hop IP address of the route against the contents of the specified prefix list. This field applies only to nonlocal routes. Select the ellipsis and choose from the list in the Match Next Hop dialog box. You can select up to four entries. To clear an entry, use the ALT key. |
MatchInterface |
Specifies if the system matches the IP address of the interface by which the RIP route was learned against the contents of the specified prefix list. This field is used only for RIP routes and ignored for all other type of route. Select the ellipsis and choose from the list in the Match Interface dialog box. You can select up to four entries. To clear an entry, use the ALT key. |
MatchRouteType |
Configures a specific route type to match (applies only to OSPF routes). Externaltype1 and Externaltype2 specify the OSPF routes of the specified type only. OSPF internal refers to intra- and inter-area routes. The default is any. |
MatchMetric |
Specifies if the system matches the metric of the incoming advertisement or existing route against the specified value. If 0, this field is ignored. The default is 0. |
MatchMetricTypeIsis |
Specifies the match metric type field in the incoming IS-IS routes in accept policy. |
MatchAsPath |
Configures if the system matches the BGP autonomous system path. This parameter applies to BGP and overrides the BGP neighbor filter list information. |
MatchCommunity |
Filters incoming and outgoing updates based on a Community List. This parameter applies to BGP. The default is disable. |
MatchCommunityExact |
Indicates if the match must be exact (that is, all of the communities specified in the path must match). This parameter applies to BGP. The default is disabled. |
MatchTag |
Specifies a list of tags used during the match criteria process. This parameter applies to BGP. |
MatchVrf |
Identifies the source VRFs that leaks routes to the local VRF (applies only to RIP routes). |
MatchLocalPref |
Specifies the local preference value to be matched. |
NssaPbit |
Configures or resets the P bit in specified type 7 link state advertisements (LSA). By default, the Pbit is always configured in case the user configures the Pbit to a disable state for a particular route policy other than all type 7. LSAs associated with that route policy have the Pbit cleared. With this intact, not so stubby area (NSSA) area border router (ABR) does not perform translation of these LSAs to type 5. The default is enable. |
SetRoutePreference |
Configures a preference value. The default value is 0. If the default is configured, the global preference value is used. When configured to a value greater than zero, specifies the route preference value assigned to the routes that matches the policy. This feature applies to accept policies only. |
SetMetricTypeInternal |
Identifies the MED value for routes advertised to BGP numbers to the Interior Gateway Protocol (IGP) metric value. The value must be 0 or 1. The default is 0. |
SetMetricTypeIsis |
Sets the metric type IS-IS. |
SetMetric |
Configures the system to use the metric value for the route while announcing or redistributing. The default-import-metric is 0. If the default is configured, the original cost of the route is advertised into OSPF; for RIP, the original cost of the route or the default value is used (applies to IS-IS routes also). The default is 0. |
SetMetricType |
Configures the metric type for the routes to announce into the OSPF routing protocol that matches this policy. Applicable to OSPF protocol only. The default is type 2. This field is applicable only for OSPF announce policies. The default is type2. |
SetNextHop |
Configures the IP address of the next-hop router. This parameter applies to BGP. The default is 0.0.0.0. |
SetInjectNetList |
Configures the destination network of the route that matches this policy with the contents of the specified prefix list. Select the ellipsis and choose from the list in the Set Inject NetList dialog box. |
SetMask |
Configures the mask of the route that matches this policy. This applies only to RIP accept policies. |
SetAsPath |
Indicates the AS path value to use whether the SetAsPathMode field is Tag or Prepend. This parameter applies to BGP. Note:
Prepend is not applicable to an internal BGP (iBGP) peer with outbound route policy. |
SetAsPathMode |
Configures if the system converts the tag of a route into an AS path. This parameter applies to BGP. The mode is either Tag or Prepend tag. The value is applicable only while redistributing routes to BGP The default is prepend. Note:
Prepend does not apply to an iBGP peer with outbound route policy. |
SetAutomaticTag |
Enables the automatic tag feature. This parameter applies to BGP. The default is disable. |
SetCommunityNumber |
Configures the community number for BGP advertisements. This value can be a number (1 to 42949672000) or no-export or no-advertise. |
SetCommunityMode |
Configures the community mode for the BGP protocol. This value
can be either append, none, or unchanged. The default is
unchanged.
SetExtCommunity |
Configures a BGP community. |
SetExtCommunityMode |
Configures the extended-community mode. The value can be append, unchanged, or overwrite. The default value is unchanged.
SetOrigin |
Configures the origin for BGP to IGP, EGP, incomplete, or unchanged. If not configured, the system uses the route origin from the IP routing table (protocol). The default is unchanged. |
SetLocalPref |
Configures the local preference for BGP. The system uses this value during the route decision process for the BGP protocol. The default is 0. |
SetOriginEgpAs |
Indicates the remote autonomous system number for BGP. The default is 0. |
SetWeight |
Configures the weight value for the routing table for BGP. This field must be used with the match as-path condition. For BGP, this value overrides the weight configured through the NetworkTableEntry, FilterListWeight, or NeighborWeight. The default is 0. |
SetTag |
Configures a tag. The default is 0. This parameter applies to BGP. |
Ipv6SetNextHop |
Specifies the address of the IPv6 next hop router. |
