Clear ARP Entries
Use this procedure to clear dynamic ARP table entries associated with the interface or VLAN.
  1. Enter Privileged EXEC mode:
    enable
  2. Clear ARP entries:
    clear ip arp interface <gigabitethernet|vlan> <slot/port[/sub-port][-slot/port[/sub-port]][,...]| <1-4059>>
Clear ARP entries:
Switch:1> enable
Switch:1# clear ip arp interface gigabitethernet 1/16
Variable definitions
Use the data in the following table to use the clear ip arp interface command.
Variable
Value
<1-4059>
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
Specifies the interface type.
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
