  • Configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
  • Configure a VRF and an IP VPN instance with an I-SID configured under it on the switch. The IP VPN does not need to be enabled for Layer 3 VSN multicast to function.
  • Enable IP Multicast over Fabric Connect globally.
  • If there is no IP interface on the VLAN, then you create one. (The IP interface must be in the same subnet as the IGMP hosts that connect to the VLAN).
  • Enable MVPN for the particular VRF.
Use this procedure to enable IP Multicast over Fabric Connect on a brouter port. The default is disabled.
You must enable IP Multicast over Fabric Connect on each of the VLANs that need to support IP multicast traffic.
The switch only supports IPv4 address with IP Multicast over Fabric Connect.
To configure a brouter port for IP Shortcuts with IP Multicast over Fabric Connect, see Configure IP Multicast over Fabric Connect on a Brouter Port within the GRT.
  1. In the navigation pane, expand Configuration > VRF Context View.
  2. Select Set VRF Context View.
  3. Choose a VRF name.
  4. Select Launch VRF Context View.
  5. Select an enabled port on the Physical Device View.
  6. In the navigation pane, expand Configuration > Edit > Port.
  7. Select IP.
  8. Select the SPB Multicast tab.
  9. Select Enable.
  10. Select Apply.
