The following table defines parameters for the filter acl ace policer command.
Variable |
Value |
<1-2048> |
Specifies the ACL ID. |
<1-2000> |
Specifies the ACE ID. |
svc-rate <0-4000000000> |
Specifies the rate of the traffic committed to be delivered. Service rate limit in kbps {0-4000000000}.The granularity is 8 kbps. |
peak-rate <8-4000000000> |
Specifies the value when exceeded causes packets to drop on ingress. Peak rate limit in kbps {8-4000000000}.The granularity is 8 kbps. |
