Configure Port Rate Limits
Configure broadcast, unknown unicast, and multicast bandwidth limiting to limit the amount of ingress traffic on a port. The switch drops traffic that violates the bandwidth limit.
  1. On the Device Physical View, select a port or multiple ports.
  2. In the navigation pane, expand Configuration > Edit > Port.
  3. Select General.
  4. Select the Rate Limiting tab.
  5. In the row for the required traffic type, configure the bandwidth limit in AllowedRatePps.
  6. In the row for the required traffic type, select true for Enable.
  7. Select Apply.
Rate Limiting Field Descriptions
Use the data in the following table to use the Rate Limiting tab.
Name
Description
Index
Displays the port number.
TrafficType
Displays the type of traffic being rate limited, either broadcast, unknown unicast, or multicast traffic.
AllowedRatePps
Specifies the allowed traffic rate limit for the port in packets per second (pps).
1–65535 configures the limit in packets for each second. The default is 25.
Enable
Enables or disables rate limiting. The default is false (no rate limit).
