View MLD Source Information
Use this procedure to display information about the MLD source.
- Select IPv6 MLD.
- Select the Source tab.
Source Field Description
Use the data in the following table to use the Source tab.
Field |
Description |
GroupAddress |
Specifies the IPv6 multicast group address for which this entry contains information. |
Ifindex |
Specifies the interface for which this entry contains information for an IP multicast group address. |
InPort |
Identifies a physical interface or logical interface (VLAN), which has received group reports for this source. |
HostAddress |
Specifies the host address to which this entry corresponds. |
MemberAddress |
Specifies the IPv6 address of a member that has sent source specific report wishing to join this source. |
Expire |
Specifies the state of this entry. |
Mode |
Specifies the current member state. This is applicable to MLDv2 compatible nodes. |
MemberExpire |
Specifies the time until the member for this source expires. |
