Applies a DHCPv6 Guard policy to a specific interface.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  2. Apply a DHCPv6 Guard policy.
    ipv6 fhs dhcp-guard attach-policy WORD<1–64>
  3. Detach a DHCPv6 Guard policy from an interface.
    no ipv6 fhs dhcp-guard attach-policy
    OR
    default ipv6 dhcp-guard attach-policy
  4. Enable device role verification attached to the port. By default, router is selected.
    ipv6 fhs dhcp-guard device-role {client|server} attach-policy WORD<1-64>
    A DHCPv6 Guard policy can be attached to a port only if the device-role configured on that port is 'server'.
The following table defines parameters for the ipv6 fhs dhcp-guard attach-policy and ipv6 fhs dhcp-guard device-role command.
Variable
Description
WORD<1–64>
Specify the name of the DHCPv6 Guard policy to be attached or detached.
{client | server}
Sets the DHCPv6 Guard device role as client or server.
