Perform this procedure to view the I-SID bridge forwarding database.
The show i-sid mac-address-entry command displays the CMACs learned on T-UNI I-SIDs. It also displays the CMACs learned on T-UNI I-SIDs for a specific I-SID, MAC address, port or port list or remote MAC address.
View CMACs learned on all T-UNI I-SIDs.
Switch:1#show i-sid mac-address-entry
I-SID Fdb Table
I-SID STATUS MAC-ADDRESS INTERFACE TYPE DEST-MAC BVLAN DEST-SYSNAME AREA-ROLE AREA-NAME
100 learned cc:f9:54:ae:28:81 Port-1/16 LOCAL 00:00:00:00:00:00 0 HOME area-20.0020
4 learned cc:f9:54:ae:2c:18 MLT-6 LOCAL 00:00:00:00:00:00 0 HOME area-20.0020
252 learned cc:f9:54:ae:38:64 Port-1/15 NON-LOCAL 00:13:0a:0c:d3:e0 128 DIST-1B REMOTE area-30.0030
All 3 out of 3 Total Num of i-sid FDB Entries displayed
View CMACs learned on a specific T-UNI I-SID.
Switch:1#show i-sid mac-address-entry 100
I-SID Fdb Table
All 1 out of 1 Total Num of i-sid FDB Entries displayed
Switch:1#show i-sid mac-address-entry 252
I-SID Fdb Table
View CMACs learned on a T-UNI I-SID for a specific MAC address.
Switch:1#show i-sid mac-address-entry mac cc:f9:54:ae:38:64
I-SID Fdb Table
View CMACs learned on aT-UNI I-SID for a specific port.
Switch:1#show i-sid mac-address-entry port 1/15
I-SID Fdb Table
View CMACs learned on a T-UNI I-SID as a remote MAC address.
Switch:1#show i-sid mac-address-entry remote
I-SID Fdb Table
View CMACs learned on a T-UNI I-SID as a home MAC address.
Switch:1#show i-sid mac-address-entry home
I-SID Fdb Table
View CMACs learned on a T-UNI I-SID as a non-local MAC address.
Switch:1#show i-sid mac-address-entry non-local
I-SID Fdb Table
The following table defines parameters for the show i-sid mac-address-entry command.
Variable |
Value |
<1-16777215> |
Displays the MAC address learned on the service interface identifier (I-SID). |
home |
Filters the command output to show only MAC addresses learned in the home area. |
mac <0x00:0x00:0x00:0x00:0x00:0x00> |
Displays the I-SID FDB details for the specified MAC address. |
non-local |
Filters the command output to show only MAC addresses learned from other nodes; not local nodes. |
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Displays the MAC address learned on the specified port or port list. |
remote |
Filters the command output to show only MAC addresses learned in the remote area. |
