Perform this procedure to display the filter Access Control List (ACL) configuration on the switch.
enable
show filter acl
Switch:1(config)#show filter acl ======================================================================================================================== Vlan/VSN ACL Table ======================================================================================================================== Acl Type AclName PktType State Origin # of Default CtrPkt Service-rate Peak-rate Vlan/I-sid Id ACEs Action Rule Id ------------------------------------------------------------------------------------------------------------------------ ======================================================================================================================== Vlan ACL Global-Action Table ======================================================================================================================== Acl Type Ipfix Monitor Monitor Id Dst-Mlt Dst-Port ------------------------------------------------------------------------------------------------------------------------ ======================================================================================================================== Port ACL Table ======================================================================================================================== Acl Type AclName PktType State Origin # of Default CtrPkt Service-rate Peak-rate Port Id ACEs Action Rule ------------------------------------------------------------------------------------------------------------------------ 1 Ingress ACL-1 nonipv6 enabled config 2 permit permit 100 200 1/1 3 Ingress ACL-3 nonipv6 enabled config 1 permit permit 800 1000 1/7-1/8 ======================================================================================================================== Port ACL Global-Action Table ======================================================================================================================== Acl Type Ipfix Monitor Monitor Id Dst-Mlt Dst-Port ------------------------------------------------------------------------------------------------------------------------ 1 Ingress Disable 0 3 Ingress Disable 0 Displayed 2 of 2 Entries
