Reset System Functions
Reset system functions to reset all statistics counters on the console port.
Reset the statistics counters:
Switch:1>enable Switch:1#sys action reset counters Are you sure you want to reset system counters (y/n)? y
The following table defines parameters for the sys action command.
Variable |
Value |
reset {console|counters} |
Reinitializes the hardware universal asynchronous receiver transmitter (UART) drivers. Use this command only if the console connection does not respond. Resets all the statistics counters in the switch to zero. Resets the console port. |
