The switch ships with default passwords configured for access to CLI through a console or Telnet session. If you possess read-write-all access authority, and you use SNMPv3, then you can change passwords in encrypted format. If you use EDM, then you can also specify the number of allowed Telnet sessions.
Important
Important
Be aware that the default passwords and community strings are documented and well known. Change the default passwords and community strings immediately after the first logon.
For security, if you fail to log on correctly in three consecutive instances, then the device locks for 60 seconds.
The switch stores passwords in encrypted format and not in the configuration file.
Subscriber or Administrative Interaction
As a network administrator, you can configure the RADIUS server for user authentication to override user access to commands. You must still provide access based on the existing access levels in the switch, but you can customize user access by allowing and denying specific commands.
You must configure the following three returnable attributes for each user:
