Display information about current IPv6 aggregate addresses.
Use BGP 4 byte AS numbers to ensure the continuity of loop-free inter-domain routing information between ASs and to control the flow of BGP updates as 2 byte AS numbers will deplete soon.
  1. To enter User EXEC mode, log on to the switch.
  2. Display information about current IPv6 aggregates:
    show bgp ipv6 aggregates [<WORD 1–256>] [vrf <WORD 1-16>] [vrfids <0-255>]
The following table defines parameters for the show bgp ipv6 aggregates command.
Variable
Value
WORD <1–256>
Specifies the IPv6 prefix and the prefix length (the length can be 0 to 128).
vrf WORD <1-16>
Specifies a VRF instance by name (the string length ranges from 1–16 characters).
vrfids <0–255>
Specifies a range of VRFs by ID number (the ID ranges from 0–255).
