Configure MLD on a Port
  1. On the Device Physical View tab, select a port.
  2. In the navigation pane, expand Configuration > Edit > Port.
  3. Select IPv6.
  4. Select the MLD tab.
  5. Configure the MLD interface parameters.
  6. Select Apply to save the changes.
  7. Select Refresh to update the changes.
MLD Field Description
Use the data in the following table to use the MLD tab.
Field
Description
QueryInterval
Specifies the frequency at which MLD host-query packets are transmitted on this interface. Values range from 1 to 65535.
Version
Indicates the MLD version.
Querier
Specifies the address of the MLD Querier on the IPv6 subnet to which this interface is attached.
QueryMaxResponseDelay
Specifies the maximum query response time advertised in MLD queries on this interface. Values range from 0 to 60.
Joins
Specifies the number of times a group membership has been added on this interface.
Groups
Specifies the current number of entries for this interface in the cache table.
Robustness
Specifies the robustness variable tuning for the expected packet loss on a subnet. If a subnet is expected to experience loss, the robustness variable can be increased. Values range from 2 to 255.
LastListenQueryIntvl
Specifies the maximum response delay inserted into the group-specific queries sent in response to the leave group messages. It also indicates the amount of time between group-specific query messages. Values range from 0 to 60.
This value can be tuned to modify the leave latency of the network. A reduced value results in reduced time to detect the loss of the last member of a group.
SnoopEnable
Indicates if snooping is enabled.
FlushAction
Specifies the MLD flush action as one of the following:
  • flushGrpMember
  • flushMrouter
  • flushSender
SsmEnable
Indicates if ssm is enabled.
NewQuerier
Specifies the IPv6 address of the new MLD querier.
DynamicDowngradeEnable
Enables dynamic downgrade of the MLD version when older version query message is received.
OperVersion
Specifies the operational version of the MLD running on this interface.
McastMode
Specifies the MLD interface mode as one of the following:
  • snoop
  • pim
  • snoopSpb
  • routerSpb
  • dvmrp
  • none
