View DvR host entries (IPv4 remote ARPs) on either a Controller or a Leaf node. The node displays the host entries learned either locally on its UNI port or dynamically from other nodes in the DvR domain.
Ensure that you enable DvR globally on the node.
- Select DVR.
- Select the Host Entries tab.
- Optional: To filter the rows based on the specific criteria, select Filter.
Host Entries Field Descriptions
Use the data in the following table to use the Host Entries tab.
Name |
Description |
IpAddrType |
Specifies the address type of the DvR host entry (IPv4 remote ARP). |
IpAddr |
Specifies the IPv4 address of the DvR host entry. |
Mask |
Specifies the subnet mask of the DvR host entry. |
L3Isid |
Specifies the Layer 3 I-SID of the DvR host entry. |
MacAddr |
Specifies the MAC address of the DvR host entry. |
L2Isid |
Specifies the Layer 2 I-SID of the DvR host entry. |
VrfId |
Specifies the VRF ID associated with the DvR host entry. |
Port |
Specifies the port of the DvR host entry. |
DomainId |
Specifies the DvR domain ID of the DvR host entry. |
Type |
Specifies the host type of the DvR host entry. |
NextHopName |
Specifies the next hop system name of the DvR host entry. |
NextHopMac |
Specifies the next hop system MAC address of the DvR host entry. |
ClearEntry |
Clears the entry if the configured value is true. |
