View Fabric Attach Statistics
If FA discovery fails, use this procedure to display FA statistics to determine if FA discovery TLVs were processed. You can also view the FA assignment statistics to determine the number of FA assignments that were accepted or rejected by the FA Server.
You can view the statistics at either the global level or at the port (interface) level.
Viewing FA discovery and assignment statistics:
Switch:1>en
Switch:1#show fa statistics
Fabric Attach STATISTICS
Port DiscElem DiscElem DiscElem DiscAuth
Received Expired Deleted Failed
1/1 3057 0 1 0
1/2 2000 0 1 0
Fabric Attach ASSIGNMENTS STATISTICS
Port Asgn Asgn Asgn Asgn Asgn AsgnAuth
Received Accepted Rejected Expired Deleted Failed
1/1 3149 3 1 3 0 0
1/2 1500 0 1 2 0 0
View a summary of the FA discovery and assignment statistics:
Switch:1#show fa statistics summary
Fabric Attach STATISTICS SUMMARY
1/1 3057 0 1 0
1/2 2000 0 1 0
Fabric Attach ASSIGNMENTS STATISTICS SUMMARY
1/1 3149 3 1 3 0 0
1/2 1500 0 1 2 0 0
Viewing FA statistics on a specific port (port 1/1):
Switch:1>en
Switch:1#show fa statistics 1/1
1/1 3057 0 1 0
1/1 3149 3 1 3 0 0
Optionally, clear FA statistics and verify that the statistics are cleared.
Switch:1#clear fa statistics
1/1 0 0 0 0
1/2 0 0 0 0
1/1 0 0 0 0 0 0
1/2 0 0 0 0 0 0
The following table defines parameters for the show fa statistics command.
Variable |
Value |
summary |
Displays a summary of Fabric Attach element discovery and assignment statistics at the global level. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
