Feature |
Product |
Release introduced |
Automatic QoS |
5320 Series |
Not Supported Use Auto-sense with IP Phone support instead. |
5420 Series |
5520 Series |
5720 Series |
7520 Series |
7720 Series |
VSP 4900 Series |
VOSS 8.1 |
VSP 7400 Series |
VOSS 8.0 |
VoIP traffic requires low latency and jitter.
If you use edge routers, configure ingress ports as core ports to treat VoIP traffic appropriately. In this case, the system trusts QoS markings that apply to VoIP traffic, and the system does not re-mark QoS settings. However, if this configuration is not sufficient, you can also apply filters, route policies, or re-mark traffic.
