You can determine the database used by the SPBM multicast module by using the following procedure.
  1. To enter User EXEC mode, log on to the switch.
  2. Show the SPBM multicast database:
    show isis spbm ip-multicast-route [all][detail][group {A.B.C.D}][vlan <2–4059>][vrf WORD<0–16>][vsn-isid <1–16777215>]
    Important
    Important
    When you use this command without parameters or use the detail or group optional parameters without specifying a VLAN ID or VSN I-SID, the command output displays Layer 3 context only. No Layer 2 context is displayed.
Switch(config)#show isis spbm ip-multicast-route
                        SPBM IP-MULTICAST FIB ENTRY INFO
Source          Group           Data ISID  BVLAN Source-BEB
192.2.0.1       233.252.0.246        16000001  101   EVP
 Total Number of SPBM IP MULTICAST ROUTE Entries: 1
The following table defines parameters for the show isis spbm ip-multicast-route command.
Variable
Value
all
Displays all IP Multicast over Fabric Connect route information.
detail
Displays detailed IP Multicast over Fabric Connect route information.
group {A.B.C.D} source {A.B.C.D}
Displays information on the group IP address for the IP Multicast over Fabric Connect route. If you select source it will also display the source IP address.
vlan <2–4059>
Displays IP Multicast over Fabric Connect route information by VLAN.
vrf WORD<0–16>
Displays IP Multicast over Fabric Connect route information by VRF.
Displays IP Multicast over Fabric Connect route information by I-SID.
