View RIP status
View RIP status.
  1. In the navigation pane, expand Configuration > IP.
  2. Select RIP.
  3. Select the Status tab.
Status Field Description
Use the data in the following table to use the RIP Status tab.
Name
Description
Address
Specifies the IP address of the router interface.
RcvBadPackets
Specifies the number of RIP response packets received by the RIP process which were subsequently discarded; for example, version 0 packet, or an unknown command type.
RcvBadRoutes
Specifies the number of routes, in valid RIP packets, that are ignored; for example, unknown address family, or invalid metric.
SentUpdates
Specifies the number of triggered RIP updates sent on this interface, that do not include full updates sent containing new information.
