Use the following procedure to display information about the IPFIX collector. The IPFIX collector can store flow information from multiple network devices.
  1. To enter User EXEC mode, log on to the switch.
  2. Display information about the IPFIX collector:
    show ip ipfix collector [<1–1>]
                                                  IPFIX Collector-Info
ID   Collector         Exporter          Source   Destination   Collector   Reachable         Exporting   Initial
     IP Address        IP Address        Port     Port          State       Via               Interval    Burst
1    20.20.20.2        20.20.20.1        2055     2055          Enabled     -                 60          5
Use the data in the following table to use the show ip ipfix collector command.
Variable
Value
<1–1>
Specifies the IPFIX collector ID.
