Configure ACE IPv6 source address entries to have the filter look for specific source IP addresses.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select IPv6.
- Select the Source Address tab.
- Select Insert.
- In Oper, select the operation type.
- In List, enter the source IP address.
- In OperMask, enter the operation mask value.
- Select Insert.
Source Address Field Descriptions
Use the data in the following table to use the Source Address tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits. |
List |
Specifies the source IP address. |
OperMask |
Specifies the mask value for the source IP address. |
