Use this procedure to configure the Link Layer Discovery Protocol (LLDP) vendor-specific information on a call server or a file server.
After you configure LLDP vendor specific call server information, the SIP Proxy of the phone is configured as transport type Transport Layer Security (TLS) port 5061. This option is available depending on the operating system of the call server.
    enable
    configure terminal
  2. To configure LLDP vendor-specific information for a call server server, enter:
    lldp vendor-specific call-server <1-8> <A.B.C.D>
  3. To configure LLDP vendor-specific information for a file server, enter
    lldp vendor-specific file-server <1-4> <A.B.C.D>
Configure the LLDP vendor-specific information on a call server:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#lldp vendor-specific call-server 1 192.0.2.0
The following table defines parameters for the lldp vendor-specific command.
Variable
Value
Specifies the Link Layer Discovery Protocol (LLDP) vendor specific information on the call server number and the IP address.
Specifies an LLDP vendor specific information on the file server number and the IP address.
