View LACP configuration information to determine the LACP parameters and to ensure your configuration is correct.
  1. View the global configuration:
    show lacp
  2. View LACP administrative information for the local device:
    show lacp actor-admin interface [gigabitethernet]
    OR
    show lacp actor-admin interface gigabitethernet [vid <1-4059>] [{sub-port]][,...][slot/all][all]}]
  3. View LACP operational information for the actor device:
    show lacp actor-oper interface [gigabitethernet]
    OR
    show lacp actor-oper interface gigabitethernet [vid <1-4059>] [{sub-port]][,...][slot/all][all]}]
  4. View LACP timer information:
    show lacp extension interface [gigabitethernet]
  5. View LACP interface configuration information
    show lacp interface
    OR
    show lacp interface gigabitethernet [vid <1-4059>] [{sub-port]][,...][slot/all][all]}]
    OR
    show lacp interface mlt [<64-6399>]
    OR
    show lacp interface mlt [id<1-512>]
  6. View LACP administrative information for the partner device:
    show lacp partner-admin interface [gigabitethernet]
    OR
    show lacp partner-admin interface gigabitethernet [vid <1-4059>] [{sub-port]][,...][slot/all][all]}]
  7. View LACP operational information for the partner device:
    show lacp partner-oper interface [gigabitethernet]
    OR
    show lacp partner-oper interface gigabitethernet [vid <1-4059>] [{sub-port]][,...][slot/all][all]}]
Switch:1# show lacp
                            Lacp Global Information
               SystemId: 00:24:7f:a1:70:00
           SmltSystemId: 00:00:00:00:00:00
               Lacp: enable
        system-priority: 32768
                timeout-admin: 3
     fast-periodic-time-admin: 1000
     slow-periodic-time-admin: 30000
         aggr-wait-time-admin: 2000
                timeout-oper: 3
     fast-periodic-time-oper: 2000
     slow-periodic-time-oper: 30000
         aggr-wait-time-oper: 2000
In the following example output, aggr indicates the port has become part of an aggregation. indi indicates individual.
Switch:1(config-if)# show lacp actor-admin interface gigabitethernet 1/1
                                  Actor Admin
INDEX SYS   SYS               KEY   PORT  PORT  STATE
      PRIO  ID                            PRIO
1/1  32768 00:24:7f:9f:c0:00 1     0x114   32768 act short aggr
Switch:1(config-if)# show lacp partner-admin interface gigabitethernet 1/1
                                 Partner Admin
      PRIO  ID                            PRIO
1/1  0     00:00:00:00:00:00 0     0x0     0     pas               long indi
Variable definitions
Use the data in the following table to use the show lacp command.
Variable
Value
actor-admin interface gigabitethernet [vid <1-4059> {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Shows LACP actor (or local) administrative information for all interfaces or the specified interface.
  • Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
  • {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} is the port or port list.
actor-oper interface gigabitethernet [vid <1-4059> [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Shows LACP actor operational information for all interfaces or the specified interface.
extension interface gigabitethernet [vid <1-4059> [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Shows LACP timer information for all interfaces or the specified interface.
interface [gigabitethernet [vid <1-4059> [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}] [mlt <64-6399>}] [mlt id <1-128>}]
Shows all LACP port configuration information for all interfaces or the interface you specify.
  • <64-6399> is the interface index of the mlt.
  • <1-128> is the MLT ID.
partner-admin interface[gigabitethernet] [vid <1-4059> [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Shows LACP partner administrative information for all interfaces or the specified interface.
partner-oper interface [gigabitethernet] [vid <1-4059> [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Shows LACP partner operational information for all interfaces or the specified interface.
