- In the navigation pane, expand
- Select 802.1x - EAPOL.
- Select the EAP/NEAP VSA tab.
EAP/NEAP VSA Field Descriptions
Use the data in the following table to use the EAP/NEAP VSA tab.
Name | Description |
PortNumber | Specifies the port number associated with the RADIUS client. |
Client MACAddr | Specifies the MAC address of the RADIUS client. |
ID | Specifies the VSA ID value as received from the RADIUS server. |
Index |
Specifies the VSA index received from the RADIUS server. |
Content |
Specifies the VSA-specific string format. |
