Enable EAP globally on the switch before you enable it on a port or interface.
    enable
    configure terminal
  2. Globally configure EAP:
    eapol enable
Enable EAP globally:
Switch:1> enable
Switch:1#config t
Switch:1(config)#eapol enable
