Modify VLAN port members to control access to the VLAN.
In the navigation pane, expand
Select VLANs.
Select the PortMembers
number for the VLAN for which you want to modify port membership.
Select the port members you want
to add or remove.
Select Ok.
Select Apply.
The VLAN port membership is changed.
