You can view the running configuration using the show command.
  1. Enter Privileged EXEC mode:
    enable
  2. View the running configuration:
    show running-config
5320-48T-8XE-FabricEngine:1>enable
5320-48T-8XE-FabricEngine:1#show running-config
Preparing to Display Configuration...
# Mon Dec 13 23:44:36 2021 EET
# box type             : 5320-48T-8XE-FabricEngine
# software version     : 8.6.0.0
# cli mode             : ECLI
#Card Info :
#  Slot 1 :
#       CardType          : 5320-48T-8XE-FabricEngine
#       CardDescription   : 5320-48T-8XE-FabricEngine
#       CardSerial#       : TB042128K-H0030
#       CardPart#         : 801107-00-02
#       CardAssemblyDate  : 20210712
#       CardHWRevision    : 02
#       CardHWConfig      :
#       AdminStatus       : up
#       OperStatus        : up
#!end
config terminal
# BOOT CONFIGURATION
boot config flags ftpd
boot config flags sshd
#boot config sio console baud 115200 1
# end boot flags
# SPBM CONFIGURATION
spbm
spbm ethertype 0x8100
# CLI CONFIGURATION
--More-- (q = quit)
