Delete a CLI User Account
Use this task to delete a user account using EDM. You cannot delete default ro, rw, and rwa users.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select General.
  3. Select the Multiple Users tab.
  4. Select the row with the user account to delete, and then select Delete.
  5. Select Yes to confirm.
