Perform this procedure to configure the Multi-area SPB layer 2 multicast I-SID list redistribution for the remote area.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select MultiArea.
  3. Select the L2 MC Redist Remote ISID List tab.
  4. Select Insert.
  5. In the ISID List Name field, type the name of the I-SID list.
  6. Select Enable.
  7. Optional: In the PolicyName field, type the policy name.
  8. Select Insert.
L2 MC Redist Remote ISID List Field Descriptions
Use the data in the following table to use the L2 MC Redist Remote ISID List tab.
6
Name Description
ISID List Name
Specifies the name of the I-SID list.
Enable
Enables Multi-area SPB layer 2 multicast redistribution for the specific I-SID list in the remote area.
PolicyName
Specifies the name of the redistribution policy.
