Enable the collection and display of IP multicast route statistics.
These statistics are not related to the interface (port) statistics. Rather, the statistics are displayed based on multicast group classification. By default, collection of multicast route statistics is disabled.
When you enable IP multicast route statistics on the Controller node of a DvR domain, the configuration is automatically pushed to the Leaf nodes within the domain.
    enable
    configure terminal
  2. Enable the collection of IP multicast route statistics.
    ip mroute stats enable
  3. Optional: Set the IP multicast route statistics to default.
    default ip mroute stats enable
  4. Optional: Disable the collection of IP multicast route statistics.
    no ip mroute stats enable
  5. View the IP multicast route statistics.
    show ip mroute stats [WORD<3-160> {A.B.C.D[,E.F.G.H][,...]}]
    The maximum number of multicast group IP addresses is 10.
Enable the collection of IP multicast route statistics:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#ip mroute stats enable
View the IP multicast route statistics:
Switch:1#show ip mroute stats
                     Multicast Stats
                           Statistics : Enabled
View the statistics for the multicast group IP address 225.0.0.1:
Switch:1#show ip mroute stats 225.0.0.1
                         Multicast Stats - GlobalRouter
GroupAddress     SourceCounter      IngressPackets       IngressBytes  AverageSize
225.0.0.1        1                  30452198             3897881344    128
View the statistics for multiple (up to a maximum of 10) group IP addresses.
Switch:1#show ip mroute stats 225.0.0.1,225.0.0.2,225.0.0.3,225.0.0.4,225.0.0.5,225.0.0.6,225.0.0.7,225.0.0.8,225.0.0.9,225.0.0.10
225.0.0.1        1                  32446194             4153112832    128
225.0.0.2        1                  32446196             4153112960    127
225.0.0.3        1                  32446197             4153113088    127
225.0.0.4        1                  32446198             4153113216    127
225.0.0.5        1                  32446199             4153113472    128
225.0.0.6        1                  32446200             4153113600    128
225.0.0.7        1                  32446201             4153113728    128
225.0.0.8        1                  32446203             4153113856    127
225.0.0.9        1                  32446203             4153113856    127
225.0.0.10       1                  32446203             4153113984    128
Variable definitions
Use the data in the following table to use the show ip mroute stats command.
Variable
Definition
Specifies the multicast group IP address for which to display statistics.
The group IP address is in one of the following formats: a single IP address or a series of IP addresses.
You can specify a maximum of 10 groups.
