Configure a static foreign source on a VRF, configuration is done at the Controller.
In the following example, vrf-10 is configured with vrf id 10.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf vrf-10
Switch:1(router-vrf)#ip spb-pim-gw foreign-source 10.0.0.1 group 240.0.0.1
Variable definitions
The following table defines parameters for the ip spb-pim-gw command.
| Variable | Value |
| foreign-source{A.B.C.D} | Specifies the multicast foreign source IP address. |
| group{A.B.C.D} | Specifies the group IP address. |
