Perform this procedure to enable Fast PoE on a specific copper port of the switch. After you enable Fast PoE, you must save the running configuration file.
The following table defines parameters for the fast-poe-enable command.
Variable |
Value |
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Specifies the port or ports to be configured. |
