Display summarized information about BGP.
The following example shows partial output for the show ip bgp summary command.
Switch:1>show ip bgp summary vrf vrf1
BGP Summary - VRF vrf1
BGP version - 4
local-as - 22610
Identifier - 27.82.217.1
Decision state - Idle
The total number of routes is 0
BGP NEIGHBOR INFO :
NEIGHBOR RMTAS STATE HLDTM KPALV HLDCFG KPCFG WGHT CONRTY ADVINT UPTime
192.0.2.1 22620 Active 0 0 180 60 100 120 5 0 day(s), 07:25:09
Total bgp neighbors: 1
BGP CONFEDERATION INFO :
confederation identifier 0
confederation peer as
--More-- (q = quit)
The following table defines parameters for the show ip bgp summary command.
Variable |
Value |
vrf WORD<1–16> |
Specifies a VRF instance by name. |
vrfids WORD<0–512> |
Specifies a range of VRFs by ID number. |
