Perform this procedure to display the Auto-sense configuration on the switch.
  1. To enter User EXEC mode, log on to the switch.
  2. Display the Auto-sense configuration:
    show auto-sense [access-differv] [data] [dhcp-detection] [eapol] [fa] [isis] [onboarding] [qos] [sd-wan] [voice] [wait-interval]
  3. Display the Auto-sense status and state on a port:
    show interfaces gigabitEthernet auto-sense [THIS IS CHANGED FOR 9.1 {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Display the Auto-sense status for Fabric Attach (FA):
Switch:1>show auto-sense fa
                                   AUTO-SENSE FA Config
MSG-AUTH                       MSG-AUTH-KEY
enabled                        ****
                           AUTO-SENSE FA Client specific config
TYPE                EAPOL STATUS    I-SID   VLANID  C-VID  MGMT I-SID MGMT C-VID
camera              Auto            100     100    untag   -          -
wap-type1           Auto            200     200    untag   -          -
open-virtual-switch Auto            -       -      -       -          -
proxy-no-auth       Auth            300     300    untag   -          -
proxy               Auth            400     n/a    400     400        400
 6 out of 6 Total Num of AUTO-SENSE entries displayed
Display the Auto-sense configuration related to ExtremeCloud SD-WAN:
Switch:1>show auto-sense sd-wan
                                 AUTO-SENSE GLOBAL Config
SDWAN       SDWAN
MULTI-AREA  VRF
HOME
                  AUTO-SENSE SD-WAN Logical Interfaces Multi-Area Config
DEST-IP            MULTI-AREA
10.10.10.10        REMOTE
20.20.20.20        HOME
30.30.30.30        REMOTE
4 out of 4 Total Num of AUTO-SENSE entries displayed
Display the Auto-sense configuration related to voice:
Switch:1>show auto-sense voice
                              AUTO-SENSE VOICE Config
TYPE   LDDP-AUTH ENABLE I-SID      C-VID      DSCP       PRIORITY
phone  FALSE            2000       2000       46         6
1 out of 1 Total Num of AUTO-SENSE entries displayed
Display the global Auto-sense wait-interval information:
Switch:1>show auto-sense wait-interval
WAIT
INTERVAL
50
0 out of 0 Total Num of AUTO-SENSE entries displayed
Display the Auto-sense status and state on a range of ports:
Switch:1>enable
Switch:1#show interfaces gigabitethernet auto-sense 1/1-1/5
                                Port Auto-sense
PORT     AUTO-SENSE   AUTO-SENSE         AUTO-SENSE       AUTO-SENSE
NUM      STATUS       STATE              PORT-DATA-ISID   PORT-WAIT-INTERVAL
1/1      Enable       FA-PROXY-RING      --               20
1/2      Enable       SD-WAN              --              10
1/3      Enable       DOWN               --               10
1/4      Enable       DOWN               --               10
1/5      Disable      OFF                --               10
