Perform this procedure to configure the optional parameters on existing SPB-PIM Gateway interfaces.
  1. In the navigation pane, expand Configuration > IP.
  2. Select SPB-PIM-GW.
  3. Select the Interfaces tab.
  4. In the row for the interfaces, double-click HelloInterval, and then type the hello interval in seconds.
  5. In the row for the interfaces, double-click JoinPruneInterval, and then type the join prune interval in seconds.
  6. Select Apply.
Interfaces Field Descriptions
Use the data in the following table to use the Interfaces tab.
Name
Description
IfIndex
Shows the interface index.
OperState
Shows the operational state of the interface.
AddressType
Shows the address type of the interface.
Address
Shows the address assigned to the interface.
AddressMask
Shows the address mask associated with the interface address.
HelloInterval
Configures the PIM HELLO transmission interval. The default is 30 seconds.
JoinPruneInterval
Configures the PIM JOIN PRUNE transmission interval. The default is 60 seconds.
