Change the VRF instance as required to configure neighbor cache on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
Perform the following procedure to configure the address translation table used to map IPv6 addresses to physical addresses. You can manually add static neighbors to the cache.
IPv6 static neighbors are not supported on SMLT.
Neighbor cache in IPv6 is similar to the IPv4 Address Resolution Protocol (ARP) table. The neighbor cache is a set of entries for individual neighbors to which traffic was sent recently. You make entries on the neighbor on-link unicast IP address, including information such as the link-layer address. A neighbor cache entry contains information used by the Neighbor Unreachability Detection algorithm, including the reachability state, the number of unanswered probes, and the time the next Neighbor Unreachability Detection event is scheduled.
- Select IPv6.
- Select the Neighbors tab.
- Select Insert.
- Beside the Interface field, select Port or Port in Vlan.
- Select a port or VLAN.
- Configure the remaining parameters as required.
- Select Insert.
- Select Apply.
Neighbors Field Descriptions
Use the data in the following table to use the Neighbors tab.
Name |
Description |
Interface |
Specifies the interface to which this entry applies. |
NetAddress |
Specifies the IP address of the media-dependent physical address. |
PhyAddress |
Specifies the MAC address. |
Interface |
Specifies a physical port ID or an MLT port ID. |
LastUpdated |
Specifies the value of sysUpTime of the last modification to this entry. If the entry was created prior to the last reinitialization of the local management subsystem, the object contains a zero value. |
Type |
Specifies the mapping type from manually configured entries. While the selection of either dynamic, static, or local is allowed; static is currently the only valid selection. |
State |
Specifies the Neighbor Unreachability Detection state for the interface
after the address mapping in this entry is used. If Neighbor Unreachability
Detection is not in use (for example, for IPv4), this object is always
unknown. The options include the following:
BMac |
Specifies the backbone MAC address. |
Cvid |
Specifies the customer VID. |
