Use this procedure to view the LLDP neighbor information.
- Select LLDP.
- Select the Neighbor tab.
Neighbor Field Descriptions
Use the data in the following table to use the Neighbor tab.
Name |
Description |
TimeMark |
Indicates the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
LocalPortNum |
Identifies the port on which the remote system information is received. |
Index |
Indicates a particular connection instance that is unique to the remote system. |
ProtocolType |
Indicates whether the entry protocol is CDP or LLDP. |
SysName |
Indicates the name of the remote system. |
IpAddress |
Indicates the neighbor‘s IP address. |
PortIdSubType |
Indicates the type of encoding used to identify the remote port. |
PortId |
Indicates the remote port ID. |
PortDesc |
Indicates the remote port description. |
ChassisIdSubtype |
Indicates the type of encoding used to identify the remote system chassis.
ChassisId |
Indicates the chassis ID of the remote system. |
SysCapSupported |
Identifies the system capabilities supported on the remote system. |
SysCapEnabled |
Identifies the system capabilities enabled on the remote system. |
SysDesc |
Indicates the description of the remote system. |
