The following table defines parameters for the show ip igmp interface command.
Variable |
Value |
gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
vlan <1-4059> |
Specifies the VLAN. |
vrf WORD<1–16> |
Specifies the VRF by name. |
vrfids WORD<0–512> |
Specifies the VRF by VRF ID. |
The following table defines parameters for the show ip igmp cache command.
Variable |
Value |
vrf WORD<1–16> |
The following table defines parameters for the show ip igmp group command.
Variable |
Value |
count |
Specifies the number of entries. |
group {A.B.C.D} |
Specifies the group address. |
member-subnet {A.B.C.D/X} |
Specifies the IP address and network mask. |
vrf WORD<1–16> |
Displays the multicast route configuration for a particular VRF by name. |
Displays the multicast route configuration for a particular VRF by VRF ID. |
The following table defines parameters for the show ip igmp sender command.
Variable |
Value |
count |
group {A.B.C.D} |
vrf WORD<1–16> |
The following table defines parameters for the show ip igmp snoop-trace command.
Variable |
Value |
group {A.B.C.D} |
source {A.B.C.D} |
Specifies the source address. |
vrf WORD<1–16> |
