Enable the Gateway Globally
Use this procedure to enable the Gateway at the global (switch-wide) level.
- Select SPBM.
- In the row for the SPMB, double-click McastSpbPimGwGatewayEnable, and then select true.
- Select Apply.
SPBM Field Descriptions
Use the data in the following table to use the SPBM tab.
Name |
Description |
McastSpbPimGwControllerEnable |
Enables or disables the ISIS multicast SPM-PIM Gateway Controller node. |
McastSpbPimGWGatewayEnable |
Enables or disables the ISIS multicast SPM-PIM Gateway node. |
