Configure the connect-retry period to specify the amount of time, in seconds, between connection attempts for peering sessions. The default is 30 seconds.
  1. Enter either Global Configuration mode or VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    Optional: router vrf WORD<1-16>
  2. Configure the MSDP peer connect-retry period:
    ip msdp connect—retry {A.B.C.D} <1-65535>
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp connect—retry 21.0.0.2 40
Variable definitions
The following table defines parameters for the ip msdp connect-retry command.
Variable
Value
{A.B.C.D}
Specifies the MSDP peer IP address.
<1-65535>
Specifies the connect-retry interval in seconds. The default is 30 seconds.
