Configuration Examples
The following example shows how you can configure an IPv6 interface and IPv6 VRRP on a DvR-enabled VLAN:
vlan create 10 name vlan_test10 type port-mstprstp 0
vlan i-sid 10 111010
interface vlan 10
dvr gw-ipv4 192.0.2.1
dvr enable
ip address 192.0.2.2 255.255.255.0
ipv6 interface enable
ipv6 interface address 2001:DB8:0::1/64
ipv6 vrrp address 1 link-local fe80::1234
ipv6 vrrp address 1 global 2001:DB8:0::1234/64
ipv6 vrrp 1 enable
exit
You cannot enable DvR on a VLAN interface that has IPv6 VRRP configuration. You must first delete IPv6 interface from the VLAN, configure DvR and then reconfigure IPv6 interface.
interface vlan 10
no ipv6 vrrp 1
no ipv6 interface
dvr enable
ipv6 vrrp address 12 link-local fe80::1234
ipv6 vrrp 1 enable
exit
