Configure a port to allow dynamic changes to EAP sessions. The default is enable.
You must enable EAP globally and at the port level.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
eapol radius-dynamic-server enable
Switch:1>enable Switch:1#config terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/4 Switch:1(config-if)#eapol radius-dynamic-server enable
