Use the following procedure to view IS-IS accept policy information on the switch.
View IS-IS accept policy information:
Switch:1#show ip route vrf test ============================================================================ IP Route - VRF test ============================================================================ NH INTER DST MASK NEXT VRF/ISID COST FACE PROT AGE TYPE PRF ---------------------------------------------------------------------------- 1.1.1.5 255.255.255.255 1.1.1.5 GlobalRouter 0 0 ISIS 0 IB 200 1.1.1.13 255.255.255.255 Switch13 GRT 10 1000 ISIS 0 IBSV 7 1.1.1.200 255.255.255.255 Switch200 GRT 10 1000 ISIS 0 IBSV 7 5.7.1.0 255.255.255.0 5.7.1.1 - 1 7 LOC 0 DB 0 13.7.1.0 255.255.255.0 Switch13 GlobalRouter 10 1000 ISIS 0 IBSV 7 100.0.0.0 255.255.255.0 100.0.0.1 GlobalRouter 0 100 ISIS 0 IB 200 111.1.1.0 255.255.255.0 111.1.1.1 hub 0 111 ISIS 0 IB 200 Switch:1(config)#show isis spbm ip-unicast-fib ========================================================================================================= SPBM IP-UNICAST FIB ENTRY INFO ========================================================================================================= VRF DEST OUTGOING SPBM PREFIX IP ROUTE VRF ISID ISID Destination NH BEB VLAN INTERFACE COST COST PREFERENCE AREA AREA-NAME --------------------------------------------------------------------------------------------------------- GRT - 101 1.1.1.13/32 Switch13 1000 1/7 10 44 7 HOME area-9.00.02 GRT - 101 1.1.1.13/32 Switch13 1001 1/7 10 44 7 HOME area-9.00.02 --------------------------------------------------------------------------------------------------------- Home : Total number of SPBM IP-UNICAST FIB entries 2 Remote: Total number of SPBM IP-UNICAST FIB entries 0 --------------------------------------------------------------------------------------------------------- Switch:1(config)#show ip isid-list test ================================================================================ IP ISID LIST ================================================================================ List Name I-SID VRF -------------------------------------------------------------------------------- test 1 GlobalRouter 3 GlobalRouter 4 GlobalRouter 5 GlobalRouter 10 GlobalRouter 22 GlobalRouter All 6 out of 6 Total Num of Isid Lists displayed Switch:1(router-vrf)#show ip isid-list vrf red ================================================================================ IP ISID LIST red ================================================================================ List Name I-SID VRF -------------------------------------------------------------------------------- test1 11 1 12 1 13 1 14 1 15 1
The following table defines parameters for the show ip isis accept command.
Variable |
Value |
vrf WORD<1-16> |
Displays I-SID list information for a particular VRF by name. |
vrfids WORD<0-512> |
Displays I-SID list information for a particular VRF ID. |
The following table defines parameters for the show ip isid-list command.
Variable |
Value |
vrf WORD<1-16> |
WORD<1-32> |
Displays I-SID list information for a particular I-SID list name. |
The following table defines parameters for the show ip route command.
Variable |
Value |
vrf WORD<1-16> |
The following table defines parameters for the show isis spbm ip-unicast-fib command.
Variable |
Value |
all |
Displays all IS-IS SPBM IP unicast Fowarding Information Base (FIB) information. |
home |
Displays the IS-IS SPBM IP unicast FIB information that the system configures in the home area. |
id <1-16777215> |
Displays IS-IS SPBM IP unicast FIB information by I-SID ID. |
remote |
Displays the IS-IS SPBM IP unicast FIB information that the system configures in the remote area. |
spbm-nh-as-mac |
Displays the next hop BMAC of the IP unicast FIB entry. |
